** I'M A BIG FAN OF THIS COOLER MASTER DEAL - OCUK EXCLUSIVE **
OcUK Staff
26 Nov 2014
Stoke
Since time began, many have asked for a HAF X in Blue, and now thanks to OCUK and Cooler Master it can be so. For a limited time only, the Cooler Master HAF X now comes with 3 FREE Mega Flow 200m Blue LED Fans, exclusively from OCUK.
Plus you get a 230mm Red LED Fan and a 200mm Black Fan that's already pre installed to chuck into another build or sell on to make the deal even better :)
Cooler Master HAF X Gaming Tower Case - Black (RC-942) @ £129.95 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Base Mounted PSU Bracket
Only £129.95 inc VAT.
ORDER NOW
I used to own the original version of HAF 5-6 years ago. It suited my pubescent mood swings pretty well.
I'm actually a little hurt. We go out our way, to provide you with nice things, at an attractive price, that people have been asking for since time began. Then you go and call them ugly :'(
Your a little hurt? Well tough crap, you have spewed out an aged design which was never good looking in the first place, then you charge £130 for it?
Go back to the drawing board and come back when you have something that doesn't look like stack of egg boxes.
Suspect most on the forum are a bit old for this sort of styling. I'd have loved it when I was a teenager.
Don't like it at all now I'm in my thirties, of course. Ugly as **** :D
You do realise this isn't a new product? It's been around for many years. It's sold well for many years, otherwise it still wouldn't be available.
I had this case and it served me well.
ok not the best looking case,
but this thing is built like a tank and very good airflow if done correctly.
I never had any trouble with the gpu's length and loads of hdd's room.
