- 4 Nov 2009
- UK
Hello OcUk!
I need some advice on what to do with something which I just did and I feel stupid for doing it. REALLY stupid.
Up until about 25 minutes ago I had a fully functioning Mac OS X Hard drive and a partition for my Windows (Vista to be specfic). However I deleted and remerged my windows patition into the Mac OS X hard drive so that I could repreat the boot camp process with Windows XP Professional instead (I despise Vista). The HD is 300gb and I partitioned 175gb of it for the Windows XP prof and left 100gb for the remainder on Mac OS X.
The partitioning process went fine (apparantly) and I inserted my Win Prof disk and it automatically restarted to start the file copying/installation process.
Before however I could copy the files I had to format my Partition (175gb) to NTFS. I however, could only see a '131'gb 'partition1' and mistakingly assumed this was the partition I had made earlier and overode it with NTFS, It then started the file copy process ready for the installation. However after it had copied the files to the partition it went back to the screen that led on to me being able to edit my file types on the partitions. So I made another mistake and cancelled it assuming it was done and so restarting into what I thought would be the bootcamp partition would start the installation.
However on restart I was not able to choose startup disk by holding option and the screen simply stayed white. I then realised my error and that I had overwrote the Mac OS X part of the HD and there was nothing to boot to. So I'm effectively running on a computer with no startup disk.
Help. I really don't know what to do. I've got the install disks for both Macintosh and Windows but unsure of what to do.
Any advice will be EXTREMELY appreciated.
