Im Confused?
Suspended
18 Dec 2007
I currently have this mobo:
EDIT:GA-965P-DS3
http://www.gigabyte.com.tw/Products/...ProductID=2314
I am upgrading my ram and am unsure whether the below RAM will go in it as I am unsure about this statement
"Supports Dual channel DDR2 800 memory"
Now is the 800 ^^ refering to the MHz of the RAM it is compatible with or does it mean something different?
So my final question is, can I put the below RAM in my mobo?
http://www.overclockers.co.uk/showpr...d=8&subcat=817
EDIT: OCZ SLI-Ready Edition 2GB (2x1GB) PC2-8500C5 1066MHz Dual Channel DDR2 (OCZ2N1066SR2GK)
dP
Looking at the Vendor list for memory some of the ram modules are PC 8500 and seemed to work at what I assume at downclocked speed, If your overclocking then hopefully you should get them near default speed if your board is a good clocker.
