- 17 Dec 2008
I am using Raid 1. When I was playing Splinter Cell Conviction. I went on to the Uplay browser, I then had a blue screen. The blue screen said process_ has_locked_pages. I booted the computer again and it said Raid 1 has degraded? Windows would not start, then windows os suggested to restore to a later date. I tried to fix the Raid degraded problem. I then messed up the Raid by deleting the Raid and then the Master Boot Record by accident. I restarted the computer and it said 'boot failure insert system disk'. I then inserted the windows os DVD disk and clicked on some tools. Then it scanned for some problems it finished and Windows started. This must have repaired the MBR? I checked each hard disk drive separately, one disk has the full Splinter Cell game and the other has half the files, which was caused by the restore? I tried to run each disk separately and they work ok? On event viewer it says Nvidia Mirror 698.63G was marked as degraded. A Raid Disk from the Array was not enumerated correctly.
