Im currently running a core2 duo...e6600...can i replace with quad core?
30 Dec 2003
Heya all...just got a bit of cash in bank and i wouldnt mind upgrading my PC for when Farcry2 arrives.
Current Spec.
Core2 duo. e6600 default speeds.
x1900 512meg.
2gig giel ram. forgotten speeds :P
and asus p5b delux mobo...
Iv got about £250bar to blow...I was thiking either new ram and gfx...or new gfx and cpu....cause iv heard quad core cpu's boost performance allot in Farcry2.
Thanks.
Adam.x
I think that a new graphics card is the most important change you could make. So how about graphics card and ram and maybe a new cpu cooler and clock your current cpu.
I am about to upgrade my gpu and cpu for farcry2, where did you hear farcry2 favours quad core ? got a link ?
if it will make a big difference this info could swing my decision.
Heya m8t...i cant remember exaclty..i think it was some were on www.n4g.com
What i read was that quad core gives a 40% boost in performance...tho i dont know if thats a boost from a single core processor..or a dual core one. But i presume it would be over a dual core as who has single core processors now when playing games :P
You need to upgrade that X1900 before getting a new cpu. That would make a huge difference, especially on a 24" monitor. Clocking you E6600 to 3-3.4Ghz would see a sizeable boost too. You will need a half decent cooler though. The Akasa AK 965 is cheap and quite good. Shame on you for running at stock speed. :p
hmmm this is putting me off buying a new processor untill i know more !
what to do, what to do !?? :confused:
im pretty sure my 8800gts is equivelent if not better than the 4670 !??
wanna see farcry2 in its full glory haha.
about the cpu, seems its either a q6600 or an e8400, or keep my current e6300 (its already overclocked a fair amount !)
confused !
With £250, buy a 4870 1Gb (the powercolor one on OCUK is a good price), get 2Gb more of the same ram, overclock your processor (should reach at least 3ghz).
Should be fine then (though I don't know about max settings for Far Cry 2 with that on a 24", we'll have to wait and see).
I have my E6600 clocked at 3.4, and its spot on. Better to make do with the hardware you have. Get A better than stock cooler and new graphics.
I agree a new graphics card should be top of your list.
With £250 id be inclined to get 4870 GFX card and 4Gb of this RAM :
http://www.overclockers.co.uk/showp...x2GB) PC2-6400C5 800MHz DDR2 Dual Channel Kit
You could then sell your current RAM / GFX card to recoup some of the cost.
I dont think anyone else has asked, but what PSU do you have?
I keep itching to upgrade myself but i just dont think the cost of a GTX260 and maybe a quad will see much of a gain over my current 8800GTX and CPU
confused !
He is very wrong. A 4670 is in no way better than a 8800 series card. I think he's on a different planet. :D
I would keep your cpu and clock it further and depending on res, possibly get a 4870. If you have a less than 22" monitor though i would stick with your GTS.
