I'm embassased to ask, but...
11 Jun 2004
Aotearoa
I have 2 HP workstations that I want to modify. One will become an HTPC and the other will be a Shuttle (or similar SFF). Forgive my noobness but I've not looked at a P4 CPU in years (I've been an AMD fiend as long as I can remember).
Can someone enlighten me as to what Socket types I am using here? One is a P4 2.8Ghz processor with HT. The other is a P4 2Ghz processor.
All this socket nonsense is confusing the hell out of me…!
Download and run CPU-Z. It should give you the exact processor details such as the package - which can then be used to figure out which socket you are using.
Thanks - exactly what I needed.
However, on the 2Ghz machine it doesn't give me a package type. Can I just confirm that a Northwood processor's socket type is a Socket 478?
yeah i think thats right... all northwoods have 512k cache (and s478) others (willemette sp?) have 256k iirc and are a mixture of s432 and s478
http://processorfinder.intel.com/List.aspx?ProcFam=483&sSpec=&OrdCode=
therefore it must be 478
