I'm feeding to an av receiver, will a sc make any difference?
25 Jul 2006
Hi
My current set up passes audio from an optical out on my mobo to an av receiver.
Can anyone tell me if adding a sc would make any difference, or would it just be a more expensive card passing the signal over to the av reciever?
Thanks
Yes and no is the answer to your question.
Yes in that a better card will probably have a more stable clock, but you're unlikely to notice any benefit until you're spending a few thousand pounds and if the reciever doesn't lock to external clock input the benefit is lost anyway.
So the short answer is no, you won't see any difference.
