Ok so I was going to splurge on an all new Haswell rig, but I dunno it just doesn't seem worth it.
My i5 750 / P55 UD3 rig ran at 4.0 GHz when I first bought the bundle, but I lost the profile due to a BIOS reset ages ago. Also, I found my Corsair H50 to be less than stellar in keeping things cool, despite re-applying thermal paste etc.
Anyway I think im going to buy a Mount Doom heatsink from OCUK today (good idea?) and try my first ever overclock. I read this guide:
http://www.bit-tech.net/hardware/cpus/2009/09/21/overclocking-intel-s-core-i5-750/1
And from what I can work out I just need to do the following? :
- Increase the Base Clock (200Mhz?)
- Disable Turbo boost
- Change the multiplier to x21
- Disable Intel speed step?
- Lower multiplyer on QPI Frequency
- Adjust CPU Voltage, what voltages should I be aiming for on a 4Ghz overclock?
Many thanks for any input!
**Edit**
I just had a quick go at a mild OC, how did I do?
http://s13.postimg.org/w1pk648nb/i5750.jpg
**Edit**
