im having trouble with HDR (tone mapping)
17 Jun 2005
Sheffield
basically - once ive composed the hdr shot, it works, then i go to tone mapping, i set the image up so it looks ok, then I click ok, the image is rendered, but it just comes up as a blank screen with a faint photomarix watermark, as does the file when i save it as a jpeg :confused:
any ideas? (all using photomatrix trial)
thanks
Just to eliminate the simple things first, why don't you try removing the program and re-installing it?
(P.S. It's Photomatix rather than matrix by the way :p )
I had this problem. I adjusted the exposure on some of the images and it eventually worked, I think.
yeah - i got it working with a different set of images, ill try the original with a bigger difference between each photo
thanks
