I'm impressed (VSO Convert X Tod DVD)
29 Sep 2006
West Yorks
After having problems with Nero / Vista and audio sync problems i switched to ConvertXtodvd. Doing so cured my audio sync problem ruling out Vista as the issue.
The program has a very clean and easy to use user interface, automatically creating chapters, audio adjustments etc...
I converted and burned a 700mb avi file in 1hr (spec in sig) and the end result was flawless.
Link HERE
* Supported video formats: Convert AVI, Mpeg, Mpeg4, DivX, Xvid, MOV, WMV, WMV HD, DV, MKV, DVD to DVD and more...
* Supported sources: existing files from digital camcorders, TV/Sat, capture cards
* Can merge up to 4 hours of material from several movies or episodes
* Supported audio formats: AC3, DTS, PCM, OGG, MP3, and more...
* Handles subtitles files (.SRT .SUB/IDX .SSA) with color and font selection, and supports tags (italic, bold)
* Video format choice: NTSC, PAL, or automatic and PULL-DOWN
* Picture output: Widescreen, Fullscreen, or automatic
* Create Automatic chapters or edit your own
* Fast preview mode to check if the source is loaded correctly
* Save the DVD structure on hard drive or burn it to a blank DVD
* Reliable burn engine integrated (supports all DVD formats)
* Fast and quality encoder (typically less than 1 hour for converting 1 movie)
* Variable options and settings for advanced users
* Control of the conversion speed vs quality
* DVD Menu control (auto-start, loop etc)
* DVD Menu edition (background, font, color)
* Customizable interface (themes, dockable windows)
* Multilingual support (available languages...)
* Optimized for Windows 2000 / XP / Vista
Try VSO its a lot better.
Not in my experience it isn't. Winavi 8 here I come if it will work :)
Saying that, other people have recommended DVD Flick and DVD Santa. I wonder if any of these use 4 cores?
Addendum: ImTOO AVI to DVD Converter v3.0 supports multi threading.
both winavi and convertx have given me out of sync audio in the past, usually a new version solves it though, convertx gets updated a lot more often than winavi
