I'm looking for a little SQL help please
17 Nov 2003
Gateshead
Hi,
I'm not much of a SQLer so looking for a little help.
Say I have the following table in SQL...
I'm trying to build a sql string that returns the first instance of each [Username] based on the lowest [Index].
The resulting table would be...
Many thanks :)
Think this should do the trick...
SELECT Username, String, MIN(Index)
FROM Tablename
GROUP BY Username
GROUP BY will return a row for each username and when used with MIN it will return the record with the lowest index.
EDIT: beaten to it :)
Afraid not...
Error...
"Column 'String' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause."
Afraid not...
Error...
You'll need to include the other column that isn't an aggregate function within your group statement (which shouldn't matter unless you have multiple entries for the same username with different string values):
Code:
FROM Tablename
GROUP BY Username, String
/Edit Just properly read your opening post...disregard the above! Will update shortly..
Code:
FROM Tablename
Not sure that will work either, he will now get one row per username, per string, so the results will look the same as the starting table.
You will need to use this:
SELECT Username, MIN(String), MIN(Index)
FROM Tablename
GROUP BY Username
Will that work though? Will the min(string) override the min(index)?
how about
Code:
select username, string, index
from tablename
where index in (select min(index) from tablename group by username)
Code:
SELECT Tablename.username, Tablename.String, Tablename.Index
FROM (
SELECT username, Min(Index) AS MinIndex
FROM Tablename Group BY username) MinFiltered
INNER JOIN Entity ON Tablename.Index = MinFiltered.MinIndex;
This way you are filtering your min values and then joining on the index with the unfiltered table to get the correct string value (assuming index is unique).
Can't use MIN(String) as I can't (don't want to) test against the value of a string.
Another way would be
SELECT * FROM Table A
WHERE A.index=(SELECT MIN(A1.index) FROM Table A1 WHERE A.Username=A1.Username))
This seems to do the trick :)
Cheers everyone for their help.
What's wrong with a basic order by?
Code:
SELECT *
FROM user
GROUP BY `Username`
ORDER BY `Index` ASC
GROUP BY will match the first row for that user and the ORDER BY shorts the desired order.
