Link aggregation by way of teaming NICs - say I've got a server with dual Broadcom NICs running as a 2Gbps team, connected to a switch with the ports configured as an LACP port. If I fit an Intel dual port NIC in a workstation and team its ports and again configure them on the switch as a 2Gbps LACP port... I'll only ever see 1Gbps between them, right? The advantage comes when two 1Gbps workstations want to communicate at their full speed with the server, that will work.
Right? I've read conflicting things but generally this seems to be how it's told. Apart from when the packets are striped across the ports in the team, in those cases it runs at full speed.
