I'm Not really sure about memory
23 Mar 2011
When I built my pc I think I just picked a random set of 8gb ram that was on offer. I use the pc to game, but don't like to break the bank to bad. I usually go mid range hardware.
So what should I have to best suit me?I shall Link what I have later when I find out, it was about 3-4 years back now
just wondering if theres something that may work better? its fine as is but i wouldnt know if that makes sense, maybe i would notice a massive difference by changing ram
If its working fine then leave it, switch to a kit that maybe has a tighter set of timings or is a bit faster in Mhz will likely gain you very little extra performance/frame rate.
