I'm old school help
11 Feb 2004
TheWirral
Ok pretty simple question.
I know these new intel cpu's do more work per cycle but ....
my old PC has a pentium4 3.4gig.
a new pc im looking into has a core2 duo 2.4gig
so is this core2 duo really gonna be much faster than my P4 3.4 gig ?
I just don't beleive it lol !! :confused:
Get with the times dude :p
The P4's were really inefficient.
The C2D's are really efficient.
You certainly will see a difference.
And then you'll start overclocking it...
You're looking at close to 2x the performance if you overclock it; and these C2D's are easy to overclock. I've never OC'ed a system in my life, but these are so easy. Have fun man
Msssive difference man, just check out some benchy's, the core 2 duo is approx the speed of a pentium D @ double the clockspeed, so basicly, an e6600 would be as fast as 2 pentium 4's @ 4.8 ghz ( or 1 pentium D @ 4.8 ghz).
So, unless that p4 is running on 6 ghz or more, the change is going to be massive.
Excellent thread gents. Just the information I was looking for as I'm pretty much in the same boat owning a lowly Pentium D 805.
