im really going insain now please help any1
Permabanned
28 Aug 2006
Manchester-UK
hi ppl
well where do i start :o
ive got this 6600gt agp card which im TRYING to get working with this dualsata2 asrock board i bought from overclocker.co.uk and i also got a 4400+dualcore cpu aswell well heres my problem ive tryed enabling that option in bios called agp p2pdeep fifo option to get this card working but nothing i can hear windows working in the background the sound etc.. but no display the weird thing is the card works flawlessly in my dads comp but not in this board or the p4vm800 i bought which is a asrock aswell supriosingly so what in the hell could this be why wont it work with these motherboards im going crazy hear please help any1 totally ******* me off now this :mad:
ps its not me psu thats a 600 watt psu
please please help some1 im on me last tether here :(
easyrider said:
what bios are you running?
try disabling fifo option
im using there latest bios 2.30 i think it is and ive enabled and disable that fifo option nothing windows loads up but theresd no display?
easyrider said:
have you tried the other vga output?
other vga output wheres that?
theres a simlar 1 but that a future cpu upgrade slot????
oh sorry no i havent ive only got a agp card i aint got a pci-e card yet but ill get 1 soon hopefully in the meantime i need this fixing as soon as hopefully?
easyrider said:
Just plug it into the DVI and then the monitor :)
cheers m8 im going to have a quick rummage throught he loft now and see if theres 1 there if not ill try it tommorrow could the problem with the card be just that the normal vga out has gone thats why iom getting no display ???
but it works in me dads old comp thats the bit whats really puzzling?
