My Pentium 4 Prescott 2.8Ghz has reported temps of... *gulp* 85-90C with SpeedFan 4.31... on partial load, so something seems SERIOUSLY amiss. To check this isn't done horrible trick SpeedFan is playing on me, what other programs are there and also, I've heard that at this temp the processors literally start to melt... Should I panic?
Thanks.
Thanks.
) two Easynote H5 laptops with Prescott Mobile 3.2 533FSB cpus in them to northwood 3.06 Mobile cpus. both had major overheating issues (80c+ loaded) and went into thermal shutoff quite a lot, also battery life was 1 1/2 hours at best and thats with speedstep enabled so the cpu was really at 1.86Ghz a lot, Northwoods actually a little faster and no thermal shutdowns, low to mid 60s loaded and 2hrs+ battery life now.
