i'm stupid!! boot.ini problem
29 Jul 2003
hi guys
had dual boot on my laptop with XP and Xubuntu, i decided to get rid of Xubuntu. So i removed the linux partition with powerquest partitionmagic. Boot up to XP and edited the boot.ini file.
reboot.
dead.......... LOL
i know i did something wrong with the boot.ini, can you pls check my boot.ini
[boot loader]
timeout=15
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
so how to fix it? i tried boot up with winXP CD there was no R option for recovery console so i can "bootcfg /rebuild"
i'm on Xubuntu LIVE CD at the moment so i can access the XP partition.
many thanks :)
PS. right now there are 2 NTFS partitions, first one is primary with XP, second one is logical one with nothing (backup)
fixmbr is what i meant, sorry been a long day :)
did read your post though :)
-edit, didn't read it properly!
when the 'Welcome to Setup' screen comes up, press F10 or r, should get you into it..
Try the below boot.ini, if you are using XP Home Edition just change the boot.ini to reflect that.
Code:
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Hope this helps!
