:/ i'm sure its 64 bit
5 Jan 2004
i've got a Intel Core 2 Duo T7200 in my lappy and i was quite sure it's a 64 bit cpu but when i used this to check it was 32 bit i.e. PROCESSOR_ARCHITECTURE was x84. is this right :confused:
well i got an e4300 which is definately 64 bit compatible and im running XP (32 bit version) it in that link it says I have X86.
So i guess it depends what OS you are using.
if u have 32 bit OS running it will say x86, if u have a 64 bit OS it will show x64.
feel free to correct me if im wrong but thats the way I see it.
Intel Core 2 Duo T7200 / 2 GHz processor ( mobile )
Manufacturer Warranty 3 years warranty
Features Enhanced SpeedStep technology, Intel Extended Memory 64 Technology, Execute Disable Bit capability, Intel Virtualization Technology
Product Type Processor ( mobile )
Cache Memory L2 Advanced Smart Cache - 4 MB
Compatible Slots 1 x processor - Socket 479
Processor Type Intel Core 2 Duo T7200
Processor Qty 1
Clock Speed 2 GHz
Bus Speed 667 MHz
Packaging Type 478-pin Micro FCPGA
Manufacturing Process 65 nm
64-bit Computing Yes
Multi-Core Technology Dual-Core
Compatible Processor Socket Socket 479
Product Display | Features | Specifications
