- 8 Mar 2020
- Southampton
Should have checked on block compatibility before buying the gpu i did but its an excuse to upgrade sooner rather than later lol
1st time hard tubing and im pretty happy,
that does look great ..In a parallel system the overall flow rate must stay the same, so whichever is the least restrictive block will get slightly higher flow. I'd imagine there isn't much in it though.Distro plate looks pretty neat, though are you bothered at all about the CPU and GPU operating in parallel in that configuration? Does the plate allow you to control how much flow each one gets?
