I'm torn! Sub - £90 case.
9 Jan 2003
Cornwall
Hi All
I'm looking to replace my PC, but I can't decide on a case.
Currently have a PHENOM MATX CUBE CASE and while it's ok I don't like how cramped it is inside.
I'm after a new case, I'd rather not spend loads but lets say the max is £89.99 if it's the mostest sexy case evs.
Currently I've been looking at:
ASUS TUF GAMING GT301 MIDI-TOWER CASE - BLACK TEMPERED GLASS - £89.99
(ohhhh straps!)
Zalman M3 PLUS MICRO-ATX CASE - BLACK TEMPERED GLASS - £50.99
(looks tidy)
H510 MIDI TOWER GAMING CASE - BLACK TEMPERED GLASS - £89.99
(Much clean)
As you can see I don't mine micro or midi ATX as I've options around that for the mobo.
I'd rather a painted back case rather than the coated like my current bitphonix as that's started to melt (kids. they touch anything and it turns to mess). I'd also like something that isn't full of sharp edges plus has space for my PSU as it's not modular so space to hide cables is a major plus (not replacing it. it's 950w and will work fine with the new system).
I know I've listed a few £90ish cases here but I'd love ideas that are cheaper if anyone's gone one.
Phanteks p350x or p360x
But you'll need a couple extra fans as it only comes with one.
Budget end = zalman i3 (not i3 edge)
A few more quid = msi mag forge 100m
I've been eyeing up the Zalman M3 Plus myself, checks all the boxes for me.
Mesh front, comes with four fans fitted, clean look to it.
I find that the Asus case looks tacky, don't like the look at all.
The H510 does look clean but I'm not a fan of the design personally.
the MSI is a bit much tbh and the Zalnan I3 looks a bit plasticy with those corner bits.
