Im unsure what psu to go with..
7 Dec 2009
Hello i need a suggestion on what psu i would require for the following
my rig is as follows
AMD Phenom II X4 Quad Core 965 Black Edition 3.40GHz
6gd ddr2 pc????
ATI Radeon HD 4890 1024MB GDDR5 x2
1 hdd sata2
at the mo i have a 600w psu but im not sure if i should get a new one or try this first? it dose have 2 6pin pci-e connection
also dose anyone know the power connetions required to run a HD 4890 card my old hd2900 had a 8 and 6 pin connection both needed to be connected otherwise there was not enough power. would this be the case with the 4890 if so i would need an adaptor to fit is there such a thing?
thanks for the help
Hi, the 4890 takes 2 x 6 pin so your current one should support it, why you got 6 gig DDR2??? There are 6 to 8 pin adpaters but as I say you shouldnt need it
