Hi,
My 2008 24" iMac (8.1) has been playing up a lot recently. It started with locks up in Safari which have got worse and worse. Often it will lock up to a point where I can't do anything and the toolbar along the top dissapears completely and I have to power down.
When booting back up it sometimes get stuck on a grey screen and it needs to be powered off again. I have used my OSX disc to access Disk Utility many times and each time its a different story. Sometimes the HDD isn't showing at all, sometimes it repairs everything all ok and the iMac will work for 20 minutes before locking up etc and now everytime I go in the HDD has gone
So I think its needs a new HDD! I have found lots of guides on how to do it and it looks quite achievable and I wondered if I could take the opportunity to go to SSD?
However I need to make use of my Time Machine backup to restore my stuff and this is around 350GB and an SSD would most likely be only 250GB. Can I pick and choose what stuff I restore or will it require me to have at least the same space as the backup?
I am assuming I will need at least 350GB so I think for now I will have to buy another SATA 500GB drive and then do the SSD upgrade and data reduction at a later date.
Any thoughts or suggestions appreciated!
Cheers
Cheers
