Imac/ Mighty mouse question!!!
26 Jan 2006
Belfast
Hey, iMac arrived but their is one little niggle im having with the mighty mouse.
There's no action for "Close the current window/Quit the current application" for the secondary button. It says you can select "other" for the action, which brings up a window of AppleScripts or something. So my question is:
How can I make it so that when I click a secondary button, it closes the current window? Also, how can I make it so that when I click a secondary button, it closes the current application?
Ahh never thought of just having a Keyboard short cut, having to get used to this.
Another question, do you know how to disable the Apple boot-up sound it makes?
A) If your mac is set to 0% volume when you shut it down, when you boot it up it doesn't make any noise.
B) Don't turn of your mac, sleep it. :p
Thats what I hoped but I dont think is the case, as the Brightness keeps going back to full everytime I have switched it on.
(Although, I have only switched it one and off about 4 times since having it lol)
lol, it aint anywhere near as bad as people here made out to be.
Will probobly be a different story once I get all my Adobe and music stuff loaded into it!
Seriously, im finding it fine TBH, no real problems, but I havent really had the chance to setup Photoshop or InDesign yet, so could just be a matter of time.
Another question, I used Winamp to stream a digitally Imported station, seeing as I dont have that anymore I assume their is sommin else I could use for this?
I went back to my trusted Logitech MX mouse after less than a few hours with the mighty mouse.
I found it twitched a lot and was less precise than the Logitech.
Cool thanks for the help, part 2 tonight is setting up bootcamp and trying out Fusion, then install all the software!
Does a right click do anything on the mac with a normal mouse?
Oh can anyone recommend a good mouse (matching is possible lol), dont want wirless.
Re: right-click, it brings up a contextual menu in a similar fashion to windows. Not enabled by default though - open the Mouse preferences to enable it.
