Just to clarify anyway, in case anybody comes across this thread.
You don't get the SSD bracket if you don't order an SSD. This means that a "proper" installation can only have a single drive. However, nothing says that you cannot use adhesive with velcro (make sure you can find stuff that can take the heat) and fit the drive using that.
I'm not aware of the bracket being available alone.
