Image Maps resized using jQuery
13 Jun 2007
Dorset
I am building a site using HTML5/jQuery
Part of the site I am using this Plugin jQuery RWD Image Maps
https://github.com/stowball/jQuery-rwdImageMaps
It creates responsive Image Maps that allows image maps to be used in a responsive design by recalculating the area coordinates to match the actual image size on load and window.resize.
Example
http://mattstow.com/experiment/responsive-image-maps/rwd-image-maps.html
It works exactly how I need it to. The only problem is it makes the text and image sit to the left and the rest of my site is centred.
If I fix the problem and centre the text/image. All is good until I try and resize the page whereupon all the maps become out of line with the image.
Any pointers appreciated.
At the moment I have 16 individual images in 4 columns that link to other pages..
This works, but when I re-size horizontally, instead of getting smaller the images move to create less columns until there is a single long column.
My solution was to create a singe image then...
Put the image/text on a re-sizable page. On the image put Map/Area tags that when clicked on link to other pages.
If you can suggest a better way please do as I am sure there are.
In the example you link to, the area maps are pretty complex, are yours?
If they are just rectangles then maybe you could use normal links absolutely positioned over the image.
Just set the margins and width as percentages and they should resize with the image.
They will also need display block and background-color transparent.
Thanks for the reply.
Yes they are simple rectangles.
