Hi all,
Been reading the threads on here trying to gather as much info as possible, have a question myself that I hope people will be able to clear up for me regarding the 360.
I have a Denon DHT-500SD and it came with an optical cable which I've attached to the HD cable on the 360, Condemned sounds awesome and so does PGR3. Glad really because I hate the whirring noise of the console itself and this drowns it out
Thats the sound sorted
I'm not convinced it looks as good as what it should though, and maybe this is solely down to my TV. I don't know. I run it at 60hz. I have a Sony 32" Trinitron flatscreen which is a fairly decent telly (DVDs look awesome, much better than my old man's 32" LG LCD he's just bought which is shocking really). I'm using an RGB scart cable (whilst saving for a HD tv).
This is my question, which HD-TV would you guys recommend? I really want to make use of the component output on my Denon and of course the 360. I'd be after something of similar size to the tv I have now. Do the games look 'that' much better or is the difference negligble? Are there any improvements in performance when using HD? Is the cost worth it?
Any help would be appreciated.
Cheers
Dave
Cheers
Dave
