Image split across two discs. How to merge?
28 Sep 2008
Britain
Hi guys,
I'm sure I have done this before but it would have been a long time ago.
Basically, I have a ghost image split across two DVDs. I have the ability to boot from USB so I would like extract both DVDs onto a decent sized USB stick.
I'm not sure if this is really possible but thought i'd ask. :)
EDIT: Lol at my post count (in relation to sig)
As above, copy both files to the USB, it should auto skip to the second file, if it doesn't it will prompt.
yes what above posters said
Ghost images work on span files so each image file is 2GB (Default anyway) before it starts writing to a new one, as long as you can insert media or have them in the same location you can just start the first one off and it will either go straight to the next or prompt for it
