Images display differently in IE and Firefox
14 Jan 2008
Hi. Am trying to design a webpage with 3 seperate images butting together vertically to create an entire image. It displays ok in Firefox, but IE inserts a gap between each image. Is this a common problem with IE?
Tearing my hair out and hoping it's something simple.
Am using some software that assists (yeh right) in building webpages. So it has templates that refer to .php files. Is the code you need to see in that?
Will try that. Although have just solved it by adding <br> at the end of img lines, so no gaps in either browser now. Guess it's best to use IE when designing a site.
nope nope nope nope nope nope.
it's far easier to design a site in firefox, and then fix the few issues with a conditional statement and then fix the problem. designing for ie will result in a worse designed site and then be harder to fix when firefox doesn't like what you have done to make ie fixed.
Also adding a <br /> (not <br>) isn't a fix as this will most likely cause more issues with other browsers. Have you checked to see what it looks like in Safari/opera/chrome?
if you are just learning imo i would only worry about ie and ff, get these right you'll learn how to design "correctly" and how to fix browser issues.
