Images in an sql table
1 Dec 2004
S.Wales
Im trying to get display output from my catalogue (SQL table)
in the table i have created a field called "image" the datatype of this field is text (or tiny text) , inside for each item a url is entered in the image field
"http://www.blahblahblah.com/blah/blah/111.jpg"
the table is then updated with this information..
in the php then i have a div which contains all fields and their results. i have included the image field in this..
see code below
Code:
$catagory=mysql_result($result,$i,"catagory");
$title=mysql_result($result,$i,"title");
$price=mysql_result($result,$i,"price");
$image=mysql_result($result,$i,"image");
echo '<div align="left" class="catagoryleft">';
echo "<b>Catagory: </b> $catagory <br></br>
<b>Title: </b>$title <br></br>
<b>Price: </b> $price<br></br><br><img src='.$image.' />";
echo "</div>";
its does not seem to want to display the image output, the page loads with no errors but no image has been loaded.
is the code correct or am i going the wrong way?
it'll be easier to save the file to your server and pop a relative link in the DB for it. you CAN put images in databases but I can't help you with how you'd go about getting it out of the MySQL database with PHP. ASP.net and SQLServer yes PHPs stuff not a hope.
HT
