- 30 Sep 2006
- Midlands, UK
Hi all,
some urgent advice required please.
I have to rebuild our design dept with new cad workstations.
2 for now, but possibly another 3 or 4 in the near future. Regardless of whether i buy and build or buy off the shelf, all will have the following installed:
- Win7 Pro x64
- Office 2010 H&B
- Autocad 2013
- Adobe CS5.5 Design Standard
It seems to make sense to do one, image it and then apply that image to the other workstations. But i've never done it, so how do i do it please?
Is it sysprep'd without serial/activation codes?
I say that but i'm not terribly sure how to do that either. I had a go once by deploying from WDS but it didn't seem to work.
Any quick pointers on the easiest and quickest way to do this would be greatly appreciated.
Thanks
edit: for any cad IT type users out there, i'm thinking of using the Xeon E3-1240 cpu as opposed to the i7 range. Your opinions on this please? (i know the Xeon won't overclock, but i'm thinking 'stability'?)
- Win7 Pro x64
- Office 2010 H&B
- Autocad 2013
Thanks
