iMame
Si.
Si.
22 Oct 2002
Melbourne, Aus
iMame hit the app store last night and the general opinion is it won't last long before it's removed.. best download it quick while you can.
which folder does the roms need to go into? I placed them in a folder with a load of zip files and just tried rescan and its the same list of lame games.
They go into the documents folder within the imame directory.
Some of the ROMS ive put in there dont show up but others do.
I think its down to the structure of the zip.
I think it will be down to the legality of any ROMS
I see.
It doesn't include iTunes file sharing however, so there's no 'official' way of adding roms unless you're jailbroken or use iphone explorer.
This may mean that it may not get pulled, but don't quote me on that. ;)
