IMGUR - crop function?
Man of Honour
24 Sep 2005
Have IMGUR just completely killed their crop function? Wtf is this 'Picsart'. It's awful.
Any ideas?
I've never looked at the image editor on umgur before. I'm well impressed! Really easy to add shapes and text over the images and even puts them into layers which you can drag around.
Not used the new tool but if you want a nice alternative you could try Photopea. It's basically a web based version of Photoshop. If you know Photoshop, you will love it. All the keyboard shortcuts are there too.
Open or drag/drop your image onto the editor, do your cropping (press C on the keyboard, or it's the fifth tool on the left hand side), then go to file > share > jpg/png and it uploads it straight to Imgur.
I use Paintshop Pro to crop, rotate, adjust brightness etc. then paste the images as imgur.
I thought I was the only one left on the planet that still uses PSP, so nice to see someone else still using it! I used PSP3/4/5 in the 1990s, then in year 2000 PSP7 came out. I did also try PSP8 but found it to be too much bloat, so stuck with PSP7 from 2000-2022 and it's still my main editor now.
Nice, an image hosting site with a BDSM feature, excellent!
I mostly use it for photography, mostly nature. If they decide withdraw it I suppose I'll find something else.
