Imgur test
19 Dec 2008
Nowhere
See if I can get this to work
Edit: hmm, that was easier than before.
Sorry gonna hijack the tread to see if I can figure out posting images
<blockquote class="imgur-embed-pub" lang="en" data-id="a/ymJOEdk" ><a href="//imgur.com/a/ymJOEdk">whatisit</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
nope
when you've added your image to imgur, get the actual image URL (you can do this by opening the image in it's own tab and then right click 'copy image address' usually)
It'll look like this:
Code:
https://i.imgur.com/fIMOGvn.jpeg
Then use the 'Insert Image' button and paste that URL into it.
Or you can type the image tags yourself.
don't use any of the stuff imgur gives you to copy and paste
