OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi all,
The popular Cougar Immersa Headset has now received an upgrade with the "Pro" version launching today. Upgraded with 50mm drivers, virtual 7.1 surround, an external USB soundcard and, of course, customisable RGB lighting.
Cougar Immersa Pro 7.1 Gaming Headset @ £79.99 inc VAT https://www.overclockers.co.uk/cougar-immersa-pro-7.1-gaming-headset-sp-002-cu.html
Cougar Immersa Pro 7.1 Gaming Headset, 7.1 Virtual Surround 360º Immersive Audio, External USB Soundcard, Retractable Microphone and Noise Cancellation Technology, PC/Phone, Tablet, Gaming Consoles
Get Immersed
Immersa Pro is the definitive gaming headset. Its 7.1 Virtual Surround audio allows you to become truly immersed in the heat of battle, hearing your enemies’ steps while they approach you to meet their defeat. With fully customized RGB backlight and various lighting modes, you are the center of attention!
Get a 360º experience with Immersa Pro's high quality 7.1 virtual surround sound. Immersa Pro's 50mm neodymium drivers bring you lifelike audio feedback during your game that allows you to compete at any level. Hear enemies approaching you and battle the best of the best in a level playing field! Moreover, the COUGAR external USB sound card provides upgraded audio effects which immerses you deeper into all gaming situations.
A Visual Feast
With Immersa Pro, 16.8 million RGB colors help you to look your best during your gaming sessions. You will have the most impressive style amongst the crowd. Fully configurable (5 different modes and the possibility to pick any color you want) and powerful backlights let you define your own gaming atmosphere, and any lighting effect you want!
Rapid, Responsive, and Intuitive Earcup Dials to Adjust the Volume and Mute the Mic
Immersa Pro's earcups provide you the most rapid and intuitive adjustments. Gamers are able to control the volume and mute the mic instantly. You do not need to find the clunky controllers with confusion or pop out of games anymore like other gaming headsets! In addition, the refined metallic diamond cut dials provide you the best control with absolute precision.
Unparalleled Comfort
COUGAR has not skimped on good quality materials, and Immersa Pro's 100 mm ear pads are proof of it. A suspended headband design with extra-large memory foam ear pads and omni-directional adaptative ear shells will provide a extremely comfortable experiences even during long gaming sessions.
The retractable microphone is flexible, convenient, durable and does not get lost.It allows you to get it out of the way when it's not needed, and further enhancing the headsets' adaptation to your needs.
Noise cancellation technologies eliminates all background noise. It delivers the crystal clear voice during gaming conversation, and make sure that your teammates will not miss any instructions.
The LED indicator mic will light up to inform you on/off functions. You only need to get a glimpse of the mic, and you will know current conditions. No matter how intense during games, it is always under your control!
COUGAR UIX™ System
A powerful equalizer allows you to adjust Immersa Pro's performance to your customization, and guarantee the top of audio effects. With superior sound card, Immersa Pro brings you the best audio and bass response. Other features such as mic volume and lighting effects further enhance your control.
Extended Compatibility
Immersa Pro is compatible with all your gaming devices, such as gaming PC, mobile phones, tablets and gaming consoles, it follows where you go.
Specification
Headphone
Driver 50mm
Max. Input Power 100mW
Sensitivity at 1KHz 100dB ± 3dB
Impedance at 1KHz 32O +/- 15%
Frequency Response 20Hz - 20kHz
Cable Length 2m
Microphone
Type Noise Cancelling Condenser
Frequency Response 100Hz to 16kHz
Sensitivity at 1KHZ -40dB ± 3dB
Impedance 2.2kO
COUGAR UIX™ System Yes
Connector Type USB / 3.5mm Phone Plug
Only £79.99 inc VAT.
ORDER NOW
Get Immersed
A Visual Feast
COUGAR UIX™ System
Specification
Headphone
Driver 50mm
Cable Length 2m
Microphone
Impedance 2.2kO
ORDER NOW
