- 3 Mar 2009
Driving to work the other day, half way there the car cuts out, dashboard lights up fully so I pull over. I give it a few minutes, then it starts up again and off I go. Couple more miles down the road it cuts out again exact same way, but this time it wont start up again (no cranking or anything). AA come out to have a look, and find the alternator has burnt out (copper wires all grey and could smell electrical burning). AA guy disconnected the alternator and charged the battery from his van, hoping it would give me enough charge to get me to a nearby garage.
Doesn't get me very far, car cuts out again, however I noticed that the dashboard was lit up and pushing the accelerator did nothing, the engine was still running (it may have been running the last 2 times but in the "ffs" moment I didn't notice). Anyway, the AA guy hooks up a portable battery and this time I reach the garage.
An alternator, new belt and battery later, told car is ready to pick up, do so, car started up just fine, and while I'm sat in the car park texting, the exact same thing happens again, and wouldnt start again (no cranking, nothing).
Garage take another look, and found a fault code relating to the immobiliser , and suspect that either my key's messed up and the signal is breaking down, or the immobiliser has gotten damaged by the failing alternator (old one was apparently kicking out 19v when it should have been 15v).
Today i'm going to try the spare key I have, but I just wanted to check if this all sounds about right? Garage said if its not the key then I could be looking at a who knows what electrical components got damaged situation and it might be worth scraping. Which I understand, but paying £450 1 day and scraping the next is a bit of a gut punch (ideally Id try and get the car home to rip out the new parts and sell them to recoup some costs first).
What say you?
What say you?
