Impactics Case & Accessories - Arriving next week!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
We have a new MiniITX case arriving, and the unique nature of these are that you can fit custom heatpipe accessories for 100% passive cooling - this is even good enough to cool LGA1155 (i3 and i5) CPU's. (LGA 1155 i7 CPU's run too hot for passive cooling) so these make for an idea HTPC which can sit at the heart of your home entertainment setup in your lounge!
Impactics C3LH-B Mini-ITX Case - Black @ £84.98 inc VAT
Simple, silent, smart!
When you want to build an ultra-compact PC there is normally a very limited choice of chassis options. Options for a high quality chassis is severely limited because of the design as a complete computer, many specifications can hardly be influenced. The German manufacturer Impactics is proposing exactly this gap and offers a system with high flexibility.
In essence it is a special case, which is designed for passive cooling. For this purpose, Impactics have the option for multiple coolers for various motherboards, which transfer the heat via heat pipes to the chassis housing where it is distributed to the lateral fins. Thanks to this modular system of interchangeable components this the ultimate mini-PC chassis.
The case is ulta-compact design but can house a slim optical and a 2.5-HDD. Thus, it requires minimal storage space and can be used almost anywhere.
The advantage of this unique solution is that the radiator fins do not require any active cooling and therefore generates no noise.
The insides of the cooling fins are each equipped with two movable mounting rails. These are the heat-pipe coupling to produce in this way the contact between CPU and cooler fins.
- Dimensions (with feet): 262 x 88 x 237 mm (WxHxD)
- Dimensions (without feet): 262 x 80 x 237 mm (WxHxD)
- Material: Aluminum (front fins), steel (housing)
- Weight: 2.44 kg
- Drives (optional): 1 x 5.25 inch slim (external) / 1 x 2.5-inch Slim (internal)
- Cooling system: heat pipes (optional) and cooling fins
- AC adapter (optional): external / internal
Only £84.98 inc VAT.
ORDER NOW
Impactics 130W AC-DC Power Supply Adapter @ £59.99 inc VAT
This power supply is designed for the Impactics C3LH-B MiniITX chassis. The external component is specified at 84 watts and delivers a current of seven amperes at twelve volts.
The internal converter circuit board is designed to contrast to 130 watts and can therefore be combined with more powerful external power supplies. However, performance is adequately sized for any compatible mini-ITX systems.
- Dimensions (external power supply): 57 x 32 x 156 mm (WxHxD)
- Dimensions (internal board): 43 x 12 x 140 mm (WxHxD)
- Efficiency: 88%
- Life expectancy: 50,000 hours
- Power: 84 watts / 3.3 V: 7 A / 5 V: 7 A / 3.3 + 5 V: 50 watts / 12 V: 6 A / -12 V: 0.1 A / 5 Vsb: 1.5 A
- Connections: 1x 20 +4 pin / 1x 4-pin ATX12V / 1x SATA / 1x 4-pin Molex / 1x floppy
Only £59.99 inc VAT.
ORDER NOW
Impactics Coolset AS-2 - for Asus & Asrock 1155 Mini-ITX Motherboards @ £69.98 inc VAT
This is a cooler set for 1155 mini-ITX motherboards from Asus and Asrock. The processor is covered with a copper radiator, the heat passes through the three heat pipes to three aluminum profiles, which are finally connected to the aluminum fins of the case.
Notes: The system is designed only for use with Core i3 and Core i5 processors. Core i7 CPUs that are compatible with the socket 1155, have an higher heat output and are therefore is not suitable for passive cooling.
- Dimensions (CPU cooler): 38 x 10 x 38 mm (W x H x D)
- Dimensions (chipset cooler): 25 x 16 x 25 mm (W x H x D)
- Material: Copper (CPU cooler, mounting profiles), nickel-plated copper (heat pipes), aluminum (chipset cooler, holding profiles), steel (top panels)
- Heatpipes: 180 x 75 mm (W x L) 1x / 105 x 75 mm (W x L) 3x
- Brackets: 180 x 15 mm (W x L) 1x (copper) / 50 x 15 mm (W x L) 1x (copper) / 50 x 15 mm (W x L) 1x (aluminum)
- Compatibility: Asus P8H61-I / Asus P8H67-I / Asus P8H67-I Pro / Asus P8H67-I Deluxe / Asus P8H77-I / Asrock H67M-ITX/HT / Asrock Z68M-ITX/HT
Only £69.98 inc VAT.
ORDER NOW
Impactics Coolset AS-3 - for Asus Atom/ION mITX Motherboards @ £54.98 inc VAT
This is a cooler for the Asus boards AT5IONT-I,-I AT5IONT Deluxe, Deluxe and E45M1 E35M1-I-I Deluxe. It is specially adapted and transmits the heat to four heatpipes which in turn is connected to the chassis cooling fins of the C3LH-B chassis.
- Material: Aluminum (heat sink, mounting profiles), steel (top panel), nickel-plated copper (heat pipes)
- Heatpipes: 4x
- Brackets: 4x
- Compatibility: Asus AT5IONT-I / Asus AT5IONT-I Deluxe / Asus E35M1-I Deluxe / Asus E45M1-I Deluxe
Only £54.98 inc VAT.
ORDER NOW
Impactics Coolset GI-2 - for Gigabyte 1155/1156 Mini-ITX Motherboards @ £71.99 inc VAT
This is a cooler for Gigabyte Socket 1155/1156-ITX motherboards. This consists of a copper heatsink for the CPU, a copper heatsink for the chipset, two copper mullions, an aluminum support profile, four heat pipes and the necessary mounting hardware.
- Dimensions (CPU cooler): 38 x 15 x 38 mm (WxHxD)
- Dimensions (chipset cooler): 28 x 13 x 28mm (WxHxD)
- Material: Copper (CPU cooler, chipset cooler, grab profiles), aluminum (Brackets), steel (cover plates, mounting plates, back plate)
- Heatpipes: 100 x 80 mm (W x L) 2x / 135 x 80 mm (W x L) 1x / 165 x 80 (WxL) 1x
- Brackets: 180 x 15 mm (W x L) 1x (copper) / 50 x 20 mm (W x L) 1x (copper) / 50 x 15 mm (W x L) 1x (aluminum)
- Compatibility: Gigabyte GA-H55N-USB3 / Gigabyte GA-H67N-USB3-B3
Only £71.99 inc VAT.
ORDER NOW
Impactics Coolset GI-3 - for Gigabyte Zacate E350 Mini-ITX Motherboards @ £52.99 inc VAT
This is a cooler for the Gigabyte GA-E350N-UD3 motherboard. This consists of a copper heatsink for the CPU, a copper heatsink for the chipset, three aluminum mullions, three heat pipes and the necessary mounting hardware.
- Dimensions (CPU cooler): 30 x 13 x 30 mm (WxHxD)
- Dimensions (chipset cooler): 30 x 20 x 30 mm (WxHxD)
- Material: Copper (CPU cooler, chipset cooler), aluminum (Brackets), steel (mounting plates)
- Heatpipes: 110 x 65 mm (W x L) 2x / 95 x 80 (WxL) 1x /
- Brackets: 50 x 15 mm (W x L) 3x
- Compatibility: GA-E350N-USB3
Only £52.99 inc VAT.
ORDER NOW
Impactics Coolset MS-1 - for MSI E350 Mini-ITX Motherboards @ £52.99 inc VAT
This is a cooling set for E350 MSI motherboards. This consists of two copper cooling blocks for CPU and chipset, three aluminum mullions, three heat pipes and the necessary mounting hardware.
Two heat pipes are run by the CPU cooler to the copper mullions, while the chip is connected via a heatpipe to the aluminum profile. The retention profiles make sure by direct contact with the cooling fins of the heat transfer case.
- Dimensions (CPU cooler): 30 x 20 x 30 mm (WxHxD)
- Heatpipes: 3x
- Compatibility: MSI E350IA-E45 / MSI E350IS-E45
ORDER NOW
Impactics Drive Bay-Less Front Panel for C3LH-B Mini-ITX Chassis @ £15.98 inc VAT
Simple, silent, smart - these are the attributes of the B-C3LH of Impactics, the Mini-ITX case that cools with the corresponding optional coolsets for different motherboards.
At stock the C3LH-B is equipped with a front panel housing a front 5.25" slim drive bay. However many HTPC SFF PC's are built without the installation of an optical drive. This replacement panel is available to "clean up" your front panel to give a more smooth crisp finish the the chassis!
- Color: Black
- Compatibility: B-Impactics C3LH
Only £15.98 inc VAT.
ORDER NOW
Impactics 2.5" Hard Drive Rails - for 5.25" Bay @ £19.99 inc VAT
This is an adapter to use a 2.5-inch drive in the 5.25-inch slim-slot of the Impactics chassis.
The HDD extender consists of two massive aluminum bars that are screwed on the drive tray and the HDD or SSD to take sides in a pincer. The massive blocks are not only for quality but also serves to cool the drive.
- Drive Compatibility: 1x 2.5-inch
- Case Compatibility: Impactics C3LH
Only £19.99 inc VAT.
ORDER NOW
Impactics 2.5" HDD Cooler for the C3HL-B Chassis @ £11.99 inc VAT
This HDD cooler made of anodized aluminum allows for better cooling of 2.5-inch hard disks. The HDD cooler is designed so that it dissipates the heat from the sides thus ensuring the hard disk temperature decreases effectively.
The hard drive cooler is a 2.5 mm thick aluminum plate which is U-shaped. For fixing the cooler onto a HDD no screws are required, but there is an option the possibility of mounting screws for added security.
- Case Compatibility: Impactics C3LH-B / Impactics C3LI-S
Only £11.99 inc VAT.
ORDER NOW
Impactics Heatpipe Manipulation Tool @ £12.98 inc VAT
This tool can be bent heat pipes by up to 90 degrees. This heat transfer tubes are supported with a diameter of six, eight and ten millimeters. The mold is by Impactics - a German specialist for passive cooling solutions.
Its cooling kits already include pre-bent heatpipes to transfer heat from the CPUs and chipsets to the aluminum fins of Impactics housing. For these sets the bending tool is not needed. In the meantime, however, heat-pipe kits are available that can be straightened out. This is exactly where this tool is used. 6-mm heat pipes can for example up to a radius of approximately 20 millimeters to be bent.
- Heatpipe Compatibility: 6/8/10 mm (diameter)
- Heat pipe bending radius: 20 mm (6 mm heatpipe)
Only £12.98 inc VAT.
ORDER NOW
Ive been looking at this on and off with a mixed opinion, I really prefer the look of the streacon FC8 fanless - slot load optical drive, front card reader and usb ports and generally a nicer shape.
HOWEVER I have just noticed this provided a heat pipe cooler for the chipset aswell as well as the mobo which the streacom does not. That is a nice little addition and goes some way to justify the price over the streacom....just a shame there is no slot for a low profile pci card to the rear :?
