- 18 Apr 2020
So long story short i bought the PC 3 years ago, and have not change the liquid or done any maintenance in that time apart from a hoover. so yes it is proper dusty at the moment.
From what i figured out is that it is a EKWB Res x3 250 installed (WC-314-EK OCUK Code) With a EK-XTOP REVO D5 PWM - ACETAL (INCL. SLEEVED PUMP) WC-9ED-EK OCUK CODE. The outside diameter of the pipe is 15.91 so 16/10 compression fittings but not 100% sure.
So i either want to add a drain valve where the red mark is located on the image which will not be the best position as it is not lowest but would be easiest. or in the blue location add Quick disconnects or a T section with drain valve but no clue what is the best option or what parts i need.
I have done a lot of reading but not sure what part goes with what. Like the res and pump is G1/4.
