I was interested in hearing thoughts from the forumites on the importance of new hardware purchases (motherboard and case mostly) having USB-C connectors.
I'm aware that the infinite wisdom of crApple means that they are likely to be removing all USB ports from their laptops and replacing with a USB-C port. But to what extent are PC peripherals likely to go down this route? I'm guessing maybe some external drives.
What other uses might a USB-C port have? Would a port on a case be a convenient place to connect a VR headset for example (although not sure it could be connected to the GPU)?
Or is it all just a bit of useless marketing guff?
