You'd be unlikely to have a happy gaming experience with just one 290x on a 4k TV anyway to be honest.
At the moment, if you have a 4k TV your only real option for playable framerates is 2x 980's in SLI IMO.
Personally I'd wait for the next set of GPU's if you are gaming on 4k TV's.
Did you read the thread
NOT ON A 4k TV WITH HDMI 2.0.....
4k TV's do support HDMI 1.0 as it's all backwards compatible.
But you need HDMI 2.0 to achieve 4k resolutions at 60hz.
Otherwise at HDMI 1.4 you are stuck at 30hz, which is pretty useless.
Thanks!
Luckily I didnt tell my friend to get some 290s for his 4K tv lol
hope AMD will have a true 4k card soon
You mean your AMD GPU goes out the window...Ok damn so tv goes out tge window then![]()
