Importing Speed Camera Locations for Satnavs
Caporegime
18 Oct 2002
West Yorks
is there any way of adding speed camera locations as custom POIs into your satnav
i read somewhere theres a database you can buy, but couldnt find it when googling.
for what its worth ive got a Navman
it does have the ability to import custom POI
just need to find somewhere that does speed cameras.
Supported Products
The PocketGPSWorld.com Safety Camera Database can be used within several different applications either for alerting of speed and red light cameras, or just to display their positions. Any other application that either doesn't accept customisable POIs as a CSV import or offer any third party hooks to allow developers to write plug-ins to warn you of cameras will not be able to support the database.
AutoRoute/MapPoint
CheckPOInt
CoPilot Live - Pocket PC 4 and 5, SmartPhone and Laptop 7
Garmin iQue M3, Quest 2, nuvi, StreetPilot 2720, StreetPilot C310, C320, C330, C340, i2, i3, i5
GPS Assist
Magellan Roadmate 760 and 800
Mapopolis
Medion - MD95000 Pocket PC
Memory-Map
Mitac Mio268/Mio269
Navman SmartST V3
Navman PiN 100, PiN 300, iCN510, 520, 550, 635, 650
PalmOne Tungsten T3
POI-Warner
PowerLOC Destinator V3, ND, Acer, GNAV
Route66
TomTom Go, Rider and One
TomTom Navigator 1, 2 and 3, HP Navigation Kit, Palm and Mobile
viaMichelin Navigation
Jet said:
Supported Products
AutoRoute/MapPoint
CheckPOInt
GPS Assist
Mapopolis
Memory-Map
Mitac Mio268/Mio269
Navman SmartST V3
PalmOne Tungsten T3
POI-Warner
Route66
wohooo
thats mine supported
reaches for wallet
have to say my 520 was an absolute bargain for £190. Does european mapping, custom POI, postcode navigation, turn by turn, voice instructions, etc.. etc..
even comes with PC software so you can edit your POI, update software, and add in the european mapping.
Not supported
AA Navigator
Kane CarPilot
Navman iCN3xx range
Navman SmartST Pro V1 and V2
TeleType
TomTom CityMaps and TomTom RoutePlanner
Which do you have?
You're welcome. I have Tom Tom on my mobile which does postcode searching and I managed to get the speed camera database before it cost any money. £50 for a GPS unit and I was on my way ;)
You can with the BMW Sat Nav as I've got it on mine.
Download the Speed camera database in ASC form from Pocket GPS World, you need to subscribe to download, about £2 a month.
/Edit. It can be a bit hit and miss though so don't rely on it 100% I use an Origin B2 alongside it.
