Okay. Basicly I was looking to cool down/ improve the air flow in my case.
Currently it has;
CPU fan - 80mm (stock AMD fan).
Graphics card (6800GT) - stock cooling fan.
PCI slot extractor fan. (Seems not very good)
120mm rear exhaust fan.
PSU has a 120mm fan.
So basicly the case body has room for a 120mm fan at the front (bottom front). If i was to mod the case's front fasica so that there would be air flow to this. Should I make this suck air in or blow air out?
The case also has 2 side vents on it. one of them has a tunnel that sits over the CPU area. I'll try get some pictures in a sec.
So what are side fans like? put one where the tunnel is? And the front fan i'm guessing should suck air in so taht air flows through the case!?
Currently it has;
