Ok so I've got a xigmatek Aquila case.
Hardware description in signature.
For cooling I have a OCUK All in one 240mm rad on the top of the case running two 120mm fans, a 200mm fan that came supplied in the front and and 120mm fan in the rear.
So the CPU is kept very cool by that radiator but my GPU regularly gets up to 83/84'C which is way too hot, and playing any modern games on a moderate overclocking causes it to crash after a short time.
So I've got a few options as I see it, listed them from least to most expensive as I figure it:
1) upgrade the case fans, I'm not sure how good these xigmatek fans are so maybe just getting more air passing through the case will help. What fan change would you recommend?
2) cut apart the AIO and re use the rad but with a new GPU block, CPU block, pipes, pump and reservoir. Again, what parts would you recommend?
3) run a water cool loop just for the GPU. I can fit a 120mm or 140mm rad behind the 200mm intake fan. Will the centre of the fan block too much of the rad? If not, what is the most economic way to do this?
4) a new full custom loop. So a new 240mm rad, pump, Res, CPU and GPU block. I could even add a second 120/140 rad to the front of the case all in one loop if it would help.
Thanks in advance.
Thanks in advance.
