Hi,
Am looking for some advice.
My rig is in my SIG.
Temps I get on Full GPU load are around 55-57 degrees with fans running at 15-20%.
As CPU is in same loop it gets up to around 50 even if it is under full load as well.
I think its not bad, but would there be a way to improve GPU temps ? (apart from running fans at 100%
Or are those temps fully acceptable and I should not be bothered ?
I think those temps could/would be lower if I would get a full block for GPU but that’s impossible....
thanks
) Or are those temps fully acceptable and I should not be bothered ?
thanks
