Improve performance?
30 Dec 2003
Birmingham
My MBP just doesnt feel as quick as it used to. Is there anything i can do to speed it up?
Im guessing it may be down to free hard drive space, but i was wondering if there was anything else to look out for.
I understand that macs auto defrag in the background, but apps just dont load as quick as they used to. Maybe something to do with 10.5.2?
There are a couple out there including Onyx, Cocktail, and Monolingual/Delocalizer which you run to carry out maintenance.
How much RAM you running at the moment anyway?
If you have less than 50% hard drive space then OS X will start choking.
You can clear out caches (~Macintosh HD, Library, Cache OR ~Library, Cache) and run a command in Terminal;
sudo periodic daily
It will ask for a password, enter it and press return.
sudo periodic daily
I think i have around 1/3 free hard drive space. I'll have a look what i can clear off tonight.
PS. Run what command in terminal?
iDefrag? Seen it used on a couple of my friends Macs and it does make a noticeable difference, especially to start-up times.
onyx, xslimmer and for that freshly installed feeling back up to a firewire drive, then boot from that, and then copy it back onto the first drive, defrag for free :)
Check the fragmentation. My MBP was being horribly slow a couple of weeks ago and I was getting the spinning ball of doom a lot. Had a fresh install of Leopard on a new hard drive around launch day, so around 6 months old. Being a lazy git I'd filled the drive up and there was around a 1GB (of 250GB!) free.
A friend suggested iDefrag ... and it was showing very very heavily fragmented. Copied a load of stuff off (100Gb) and ran a full defrag which took 14 hours. I had to install Tiger onto an external drive as iDefrag needs to unmount the main disk.
Now all is good. :)
