Improved power steering after fitting a new battery
29 Jun 2004
I could be talking utter rubbish here (and I suspect I am!), but here goes...
I replaced the car battery and now the steering feels lighter and more responsive.
The rational me is saying it's rubbish and that I'm experiencing some sort of plecebo. However the irrational me is thinking that the power steering pump is an electrical item and therefore could benefit from a better power supply. So, what do you think?
Don
18 Oct 2002
Wargrave, UK
Depends on how your PAS is provided. If it's hydraulic then it will be powered from an auxiliary belt from the engine. If it's electric then yes, a new battery could indeed make the steering feel better.
5 Mar 2004
Aylesbury
Again, could be talking utter rubbish, but if you've got a duff battery then the engine is working harder to power the alternator to top it up. WItha new battery , there's more engine power to the steering pump?
Caporegime
24 Oct 2012
Godalming
A new battery will always affect a car. You don't realise how the performance deteriorates over time because it's so slow, but popping a new one in will bring out the best in an instant so it's really noticeable.
I also tend to replace batteries after the first few signs of wear, hate dealing with crap batteries.
1 Mar 2010
but it's a safety critical system if the battery can't deliver the required current to power the steering electric motor, within spec, you'd expect it to throw a warning code ... limp mode ?
equally for a traditional hydraulic system (with feedback) too, I'd assumed there is a pressure detector; if there were a leak you could be pretty dead.
13 Jan 2004
Probably more likely that you have Electric Power Steering which is configurable and the battery change has cleared your setting. What car is it? By default my Nissan has light ePAS settings but can be changed to 'Sport' which makes the feel heavier.
