Improving meeting audio? Where to start!
DHR
DHR
30 Apr 2003
Interested to see what people are using for desk mic setups without being overkill?
I'm looking at improving audio for work meetings specifically, replacing an old poly combined cam/mic/speaker device I'm using.
Not wanting to go full streamer with a desk full of kit, but definitely want something a little more hifi / studio quality for video calls than what I have - but as affordable as possible (I'd be looking at second hand first at the moment)
Where to begin? Not something I've looked to do before?
It's not hi-fi/studio quality you want anyway, for video calls, what you want is good processing that makes speech super clear, will even out quiet and loud people on the other end and have a great microphone array with noise cancelling..
In work we have many solutions, but for individual offices, the best performing and value for money are the Jabra desk speakers, we have several Jabra 510's and a couple of newer Jabra Speak 2 55's..
These are really really good, USB, loud, clear, full duplex and great microphone arrays and literally made for the job..
Amazon have the Speak2 55 for £85 (whilst it says its on offer, its literally only worth that as it replaces the 510 which is <£80) https://www.amazon.co.uk/Jabra-Bluetooth-Speakerphone-Noise-cancelling-Full-range/dp/B0BWKDDXTR?th=1
There is the Yealink CP700 which is £50 on amazon, but that has half the microphones and I don't think handles voices as well from its speaker, it doesn't equalise them and they don't sound quite as natural..
Then get any camera you like, we have such a mix in work, the Insta360 Link 2C is expensive at £110 but they are top notch, larger sensors, 4k allow great auto framing etc, but are a bit overkill!
  • Like
Reactions: DHR
I have a Blue Yeti (still made) and Blue Yeti Pro (discontinued but was a higher quality version of original yeti).
For webcams I have a Logitech Brio and an older Logitech C920 Pro. I have 2 setups one in home office and another in the lounge connected to a HTPC.
Any of the products above are more than enough for Zoom, MS teams type stuff. The video quality on the Brio is quite a bit better than the older C920 Pro but the c920 is still ok for business type meetings.
What machine do you use?
I’m fortunate at work we get MacBook Pros which have webcams, speakers and mic that are just excellent already with MacOS and I also bought AirPod Pro 2s that I use when I can’t be on speaker and they are again just excellent out the box.
Tried various on-ear Jabra headsets etc but nowhere near as good or comfortable for me.
I’ve also used audiophile headphones (Philips Fidelio X2HR) with a Modmic connected and whilst they probably had the best audio quality, they were not comfortable all day. The AirPods are and they have ANC…
Finally, your environment can make a big difference for those listening to you. If it’s small, with hard flat surfaces, you may sound like you’re talking from the bathroom. So think about where you sit and what options you have and also soft furnishings that could help dampen sound, like curtains, cushions etc. It can make a surprising improvement.
Now I’ve finally figured this out post-covid, we are returning to the office…
A directional cardioid mic (Chinese ones are fine) will pick up more of your voice, less of the reflections. Sound treating your room is the ideal if you really want the best audio.
For video, any decent webcam will work, Logitech C920 is solid. Lighting is what will make it look more professional, so a big soft box or ring light.
You can plumb most modern SLRs in as a webcam so you could go that route with a wide, fast aperture prime lens, if you really wanted to go to town. A bit much for meetings though really.
I recently switched from my Logitech headset (getting uncomfortable in long meetings) to an Elgato Wave Neo microphone.
Teammates say audio quality is much improved. I have it sat right in-front of a desktop speaker used for meetings, and no feedback or noise comes through in Teams.
Also using a Facecam Neo webcamera too, much better picture than my old Chinese amazon camera I had that suddenly wouldn't work with Windows 11.
I use a Jabra Speak2 40 as I don't really like wearing a headset for a prolonged period of time when working.
The device itself is exceptional quality and not had any issues with it, Jabra make some quality products for work/productivity.
As for camera, been using a Logitech C920 which I can't fault. With darker days amongst us now I pair this with a monitor backlight to compensate for low brightness.
What is your internet connection like?
Yep unfortunately. I've tried a few speaker phones now, and although audio quality my end was good, people always said I sounded to them like I was far away, or had quite an echo. These were just used in a normal room too, with the device(s) about 60cm away from me. Sound treating I feel would be a must. So for me, I don't think you can beat a good headset with a boom mic. I agree with most, they can get uncomfortable.
I'm currently using Sennheiser Momentum 4's for work and they are comfy. Although now I find I get sweaty ears after long calls lol. Also, I have noticed in a noisy environment they aren't good for calls (no boom mic). Been told a few times now that they just pick up voices around me - which they shouldn't. So when I use at home, thankfully, it is quiet and all is well. To be honest they are not meant for office work really. :)
I've had a c920 they're great once you fix the blue balance on them.
While there is noise gating, etc. and other processing to clean up the mic feed for best quality you ideally want an external interface (ADC) as close as possible (short lead length) to the mic and digital for the longer run back to the PC or laptop or whatever.
One of my Blue Yeti mics I run a 5 meter usb cable. I was getting disconnects with regular USB cables, but i found some discontinued Lindy Premium Gold USB cables being sold cheap, and they allowed a 5 meter cable length without any disconnects.
Even better in the case of the Yeti, etc. where there is no lead length to speak of from the mic to the ADC, but obviously there are limits to the USB cable length, wireless being the other option.
I'm using a Hollyland Lark wireless lapel mic - discrete, no deskspace needed and still sounds great (works on PS5 also and provides great quality). Couple that with some IEMs or one of many over ear headphones I have depending on who I'm meeting with. Only problem with the Hollyland is I end up forgetting to unclip it and end up walking around the shops with it still clipped on!
