Hi all, recently upgraded to a new PC for the first time in a few years. Have opted for a mostly quieter build, be quiet case with 2 Silent Wings case fans as stock. I have a decent AIO CPU cooler and a Suprim X GPU which should have good temperature management. I'm finding the temps while gaming for both getting relatively high, although safe, and am wondering if an extra front intake fan would make much of a difference?
Specs - CPU 5900x, GPU 3080 Suprim X
Currently reaching 84 and 80 celsius respectively
I understand these are workable temps although they do seem a tad high to me, while I have traded temp performance for lower noise just looking to see if extra fans will bring down the temps under load to a more comfortable point.
Cheers
Cheers
