I posted before about watercooling and have decided i will just cool the CPU prob with a swiftech H20 220.I still have air flow prob though. I have a cosmos 1000 (the original cosmos not the S with the side fan) and I have heat issues. Spec is as per signature.
Airflow is poor at best. Trisli setup is really hot and the airflow has to pass the GPUs before getting to the CPU and northbridge. I have already made some improvements, putting in a much better intake fan at the bottom of the case. I have two antec spot cools pointing at the cards which keeps them cool but pulls air away from the flow to the top of the case. I have modded three of the 5.25 drive bay covers with an intake fan too and added a fan to cool the HDDs.
Even with that things are still hot (CPU creeps into the 70s under prime load) north bridge occasionally overheats playing games.
I think i will watercool the CPU and then mod the cae with three 120mm fans in line with the GPUs (horizontally). I will get rid of the spot cools as the GPUs should have plenty of airflow, this should help some air to reach the CPU. I think i will also add another 120mm fan over the cpu / NB.
Before i hack my case to bits does this sound like the best plan? Better to go for 1 or 2 bigger fans? Anyone else modded the cosmos to improve airflow?
