Imp's Drive Info
2 May 2004
Just got my 1.5TB drives today and it seems the "Imp's Drive Info" sidebar program doesn't support terabyte drives?
Is there an updated version, or a better program I can use to monitor the space used on my PC?
Thanks,
Craig.
The side bar gadget I use to monitor my drives is from the hobby lounge. I have no idea though if the one I use has an upper limit that can be found.
Once you get them all make sure you get its homemade skinner. THLskinner I think it's called. It's a little one that I install but never have on the bar itself unless I'm ready to bulk skin.
