in a pickle
Crossfired 290's will KILL it.
But (and this is a big but) what do you really need with all that power? Unless you are running a 4k screen anytime soon or want to brag some benchmark scores then a single slot 290 will run anything you throw at it as long as your CPU is up to snuff.
well my cpu is needing something to keep it busy 4930k @5ghz
i like using anti aliasing and settings to max i love the eye candy, i am a sucker for visual quality
Well if you play Crysis 3 a lot then maybe it'll help with all that...can't think of many games that would really benefit.
I have a single 290x and BF4 runs at Ultra settings 100fps+ (minimum approx 70fps) at 1080p.
You can override the AA in games easily with RadeonPro to have supersampling instead of MSAA, etc. It works on most games and can make them look amazing.
